2002 Jeep WJ
I am doing the same thing. I have found that superbrightleds.com and plasmaglow.com are pretty good. Leds from V-Leds are good quality, but I have had bad luck in getting things shipped. I ordered all the dome lights and foot well lights the first week of March and so far I have only received the foot well lights. V-Leds originally said the lights were back ordered and would be available mid-March, then early April, then mid April now its says early May. I would avoid V-Leds for sure. Superbrightleds has a large selection and good quality leds and fast shipping. Plasmaglow is best for exterior lights like turn signals and running lights. I have read that Putco and GTRLighting.com are good as well, although I have not ordered from them. Good luck and I hope this helps.
05 WK
I have used Superbright LED's for years without issue. I have read good things about AutoLumination & V-Leds but never used personally
WJ Limited
I used superbrightleds to do my speedometer gauge cluster, it's also a good site because it tells you what size your bulb is and what it's replacement sizes are in LED. If you do the tiny lights, you can either solder or figure a way to run a LED strip.
