1 - 20 of 25 Posts
Jeep Grand Cherokee
Hey guys can I text message through my new 14 cause I don't know how to???
Not sure if you can text or just reply... are the uconnect reading messages for you?
Mine does that, but I haven't actually tried to text anyone, maybe through voice command since it's hard to believe it would let you actually text on the touchscree
Jeep Grand Cherokee
Ya that's what I meant. It won't let me text through voice command. Am I doing something wrong
Jeep Grand Cherokee
I will give it a try and let you know
Please do because I've tried it multiple times and I can't get the messages to come up
I tried a few things and it didn't work, I could't even reply to a message even with the car into parking, bummer! Then when I got home I looked at the voice command manual and I wasn't really using the commands it is expecting, so maybe it will work, try the commands on the phone section there is supposed to be a "send message to" command, I will give it a try as well
http://www.driveuconnect.com/pdf/UconnectVoiceCommands.pdf
Jeep Grand Cherokee
Ya I tried that but because iPhone doesn't have messaging in Bluetooth it won't work. All of the buttons (phonebook recent calls etc) are all highlight and messaging is darkened out and unclickable. Don't think it works with iPhone. Only android. I'm gonna try it with my buddies droid and see what happens
'15 SRT
Yea I def had the right command this afternoon for messaging with my iphone 5 and it doesn't work. Must be the phone.
Me too... the message actually seems to go through, but it doesn't actually go. It's okay reading messages, but it can't send!
Jeep Grand Cherokee
Discussion Starter · #10 ·
Still don't know how to read a text from my car.... Any help would be great. Are you using and iphone?
yes, iphone! if you get a message it should just pop up on the screen and it's gonna say you have a new message. caveat is that you can't read messages that are already in your phone, you can only read the ones you received while the phone is paired to the car
Jeep Grand Cherokee
Discussion Starter · #12 ·
See I don't get that option. Is there a setting I need to turn on in my phone?
Jeep Grand Cherokee
Discussion Starter · #13 ·
I just went into my bluetooth options and turned on show notifications. Maybe that will change it
Needs to support Message Access Profile (MAP) over BT. Not sure on Apple's support of that...
Android did this well up until 4.2.2 when they integrated v4.0 of the BT stack. Now it is broken... (Unless you are like me use custom ROMS on your phone ;), but, you're iOS so I know you aren't).
'10 Nissan Maxima SV
Messaging with iPhone is not supported and is crippled to some extent. I read it somewhere on the UConnect website regarding compatibility. If I get around to the link I will post it. But as it stand, outbound messaging is not supported with iPhones :( Maybe with iOS 7 :O
Jeep Grand Cherokee
Discussion Starter · #16 ·
Ya hopefully!!
Snapshot from the UConnect support site - found under Bluetooth Application Pairing Info is similar on iPhone 4/4S/5
This is what is in the question mark info next to Voice Texting (Free-Form Text)
Powerful, cloud-based voice recognition allows you to dictate free form text messages, and send them from your Bluetooth-enabled phone without taking your hands of the wheel or focus from the road. Requires a phone that supports bluetooth MAP protocol.
Jeep Grand Cherokee
Discussion Starter · #18 ·
Right from Uconnect.....iPhone 5 does not support MAP which is required to do voice texting
iPhone 5 does...Apple just won't allow it :slapfight:
(My home and family are completely Apple-fied before any of you start :p)
Jeep Grand Cherokee
Discussion Starter · #20 ·
^^^ what he said....100% correct.
1 - 20 of 25 Posts
