1 - 6 of 6 Posts
Rear defroster not working
Checked elec. tabs under grid cover and , fuse but both are fine
under fuse box diagram does not specify
2014 WK2 Overland
Do you have a multimeter? When you activate the rear defrost, does the indicator on the switch illuminate?
1) Yes
2) yes, what does that tell you ?
Thanks Ratchet I will check these things this week
2014 WK2 Overland
1) Yes
2) That tells us that at least we're getting power to the switch. I haven't seen any failed/broken grids unless the owner installed aftermarket window tint and since removed it damaging the grid itself. I have however seen quite a few of the tabs have a poor connection to the grid as well as the wiring to the tab itself get pinched or damaged near the headliner/rear lift gate frame. In a few rare cases, I've seen the wire ever so slightly pull out of the connector pin that attatches to the tab on the glass.
Discussion Starter #5
Have you ever heard of the whole grid working but not getting as warm as before ?
2014 WK2 Overland
Personally, no. I have not. The grid will either have continuity or not. In the situation you just mentioned, I could see the supply voltage being a bit lower than the known good voltage and that may cause a low heat condition. If that were the case, there is an underlying issue between the voltage source and the input on the grid.
1 - 6 of 6 Posts
