Good day, I have a 2014 Jeep Grand Cherokee 3.0 Diesel with a fault code P 020B-00 says injector 2 Timing not the same as other injectors. I have tested the injector at a diesel injection shop and tests okay. Swapped injector 1&2 and fault still says injector 2. Checked wiring to ECU and resistance on harness from injectors to ECU and tests okay. Checked pins on ECU plug and all look good. Please can you advise if there are any other checks I may have missed to diagnose this fault.
Any advice will be greatly appreciated.
My first guess (and it is a guess) would be the PCM. Also I think those injectors are programmable to the PCM.You would probably have to go to your dealer.
I have coded them as i changed them problem stays there. Also see the car smokes a bit. Here is a injector correction graph i took of the jeep. Left top is cylinder 1
220816
