1 - 20 of 54 Posts
Can anyone confirm that the correct part # for a Jet 180 thermostat for a 2014 GC SRT is "10183"? Thanks!
2014 Jeep SRT
After installing mine it looks like the temp is going to sit on 190 degrees. OEM had it set at 200.
How hot does yours run after the 180 install?
· Premium Member
I watched mine a couple times and it ranged from 184-190. I didn't pay any attention to oil temps
· Premium Member
Installing mine tonight. Silly question... Should I wait a considerable time for the engine to cool before making the swap?
· Premium Member
be sure to "burp" it when done and replace the lost coolant
· Premium Member
Agreed, any input on when I will know it is ok to make the swap. 1-2 hours...visual inpection, etc.???
· Premium Member
I just caught what I could and then added a tiny bit of water. It doesn't take much if your careful
· Premium Member
Installed the tstat but think I have a problem. While driving the coolant temp drops to about 184... While parked for about 5 mins I saw the temp go up to 215.
Is this working OK? I'm burped the system as best I know how. My apologies for the paranoia. I'm very comfortable with electrical stuff but not mechanical when it comes to cars.
Edit... While typing this message she is running at about 204 just sitting here... Does the Tstat need to break in?
· Premium Member
let her run a bit with the radiator cap off
Thanks, did that and she began to runneth over lol. I'll see how she acts heading to work in the am.
· Premium Member
On the ride to work she was right at 184 the hole way. When i parked it started to climb to 192 before i needed to head inside.
1 - 20 of 54 Posts
