I have an 05 wk limited that I bought used. The jeep came with two keys, one of which stopped working last week. I replaced the battery, and that did not solve the problem. The key will still start the car, but it won't open the doors, I thought if the key was dead, then it wouldn't start the car, is that the case?
The second thing is that I found out while both keys will turn in the ignition, neither key when put in the door lock will turn. In essence the only way to unlock the doors is electronically with the key, is this normal?
Third, can you add an after market remote start to the vehicle? If a new key is going to cost me a couple hundred dollars, It may make sense to just get a remote start and bypass the keys all together.
Thanks for the help.
