MY GF has a 2014 MK Compass limited I am looking to upgrade to led head light bulbs. The halogens that came with the car are 9012 I have tried both 9005's and 9012's led's with both a canbus and no canbus and a few different brands and wattages. Right now there are 2 X 9012 phillip cheap *** halogens in there one is 55w the other is 65w when the led's are in the car and the car is not running they do not flicker but once the car is running they flicker... the 9005's flicker no matter what..
What can I do? I have tried some of the higher brand names (not just buying $20 sets from ebay the last set was over $100 and was rated one of the top 10 brands this last year)
And as soon as I put the halogens back in the work just fine...
PLEASE HELP!!
You need to put in a pair of Morimoto CAN BUS anti-flicker modules.
The Pulsed Width Modulated (PWM) power output of the vehicle is what is causing the flickering so it will happen when the engine is running.
As I stated once all ready I have tried a few different high name brands to no avail with canbus systems
