1 - 13 of 13 Posts
I purchased these at my local aftermarket shop!for my license plate lights) Anyone know if these fit!?...for one there's no way in hell my fingers fit in that small ass space to take the stock ones out and two I tried a needle nose and I feel like I'm bout to break the bulb! It's a 12' altitude.....if the pic don't work the lights are united led light bulbs 12v dc
Light Automotive lighting Auto part Headlamp Fictional character
2012 GC Laredo X
I used a flathead screwdriver to kind of force them out. I didn't car if they broke(they didn't).
After spending about an hour I said fck it...I'll wind up scratching or putting the screw driver thru the door
2012 GC Laredo X
Try a pair of needle nose pliers. You will get them out. The glass is pretty tough and you won't break it if you use apply a little pressure.
I used needle nose pliers when I changed mine. Took all of 3 minutes total to remove and replace with LED bulbs. I was pretty surprised at the strength of the original bulbs...I squeezed on em pretty good when removing them.
Discussion Starter · #10 ·
Ight call me dumb as I'm gonna attempt to so it again I only pull the bulb out? Not the housing that its in? ?
1 - 13 of 13 Posts
