Wanted to see whose all running led bulbs in the stock housings and how are you guys setting up resistors..
Instead of buying the led tails, I thinking of getting the stockers tinited and running 2 sets of led bulbs..
My question is do I need to run 2 set of resistor a side?? And which wires to plug them into??
I have the pinouts thanks to the Mopar connectors website but stumped at which wires to tap.. I know the obivious ground but which + source to tap..
Here's the pinout: (right side the same minus the trailer signal wires)
1 WT/TN BRAKE LAMP SWITCH OUTPUT
2 RD/DG FUSED B(+)
3 WT/DB TRAILER TOW TURN SIGNAL
4 WT/YL TRAILER TOW TURN SIGNAL
5 WT/VT FUSED PARK LAMP RELAY OUTPUT
6 WT/LG BACKUP LAMP FEED
7 WT/DG LEFT REAR TURN SIGNAL CONTROL
8 BK GROUND
I want to get so feedback before I start blowing fuses :lol:
Anyone done this in there 05-06??
Isaac
2 RD/DG FUSED B(+)
8 BK GROUND
Isaac
