I've owned several Audi's in the past, and own one now. Using VAG-COM from a business named Ross Tech, I can re-code most modules on the car without problem. It's a fairly simple program to use, allowing the owner to re-code to, say, European lighting...or add whatever part...or make the windows roll-up/down with the key fob only, data log, etc.
I've tried using my software & cable to read the generic OBD-II software, but I can't even do that with the '14's CAN-BUS system. Does anyone know what software is avaliable now to read, and edit, the ECU/CAN-BUS?? Has anyone successfully re-coded a module on the new Jeeps??
