Hi all-
New to the site, but have been a Jeep owner for a while. I am, however, new at entertaining the thought of putting either a leveling kit or lift kit on my Jeep. I have a 2016 Grand Cherokee Limited 75th Anniversary addition 4x4, without the air suspension. Thus I'm interested in one of those two options.
I know this subject has probably been addressed over and over again, but your input on some of my questions would be helpful. You may be able to see some of the pros and/or cons to each that I am not aware of.
For what it's worth, primary use of the vehicle is a daily driver, but I also take it off road often for outdoor activities. I am not rock climbing nor looking to push the boundary of the 4x4 system on the Jeep, but I do use the 4x4 in dirt, rock, sand, snow...etc.
Option 1- Put a leveling kit up front. Pros/Cons to just adding a spacer? If I did this, which leveling kit would you suggest? Does anyone have experience with this in your Grand Cherokee? Does it sag in the back once you load it up with gear? Ride quality good?
Option 2- Put a lift kit on. Specifically, I am interested in the Old Man Emu 2" lift kit. Anyone have experience with that setup? Pro/Cons? I heard that by installing this kit, the front of the Jeep still sags lower, is that true? Did you level it out also?
As a sub-question to Option 2, if I did the lift kit, I would probably want to put on bigger tires naturally. Currently, my Jeep has 30.5" diameter tires. 265 width. (265x50x20). I have heard that putting 33" tires on it would require re-gearing, however, what about a 32" tire? Would I still need to re-gear? Currently, the stock gear ratio of the Jeep is 3.45 I believe. I found several 275x55x20 tires that would give it that extra 1.5" diameter. Thoughts on this?
Also, if I went with the 275 tire (slightly wider than my 265), would I run into any rubbing issues or need wheel spacers?
Any thoughts, experiences, tips, or suggestions are appreciated!
