Here are some for 05s-07s, Some might work for 08s-09s :
UCONNECT – Using with radio’s steering wheel buttons, Hold down the middle left button behind the steering wheel to place a call and then again to hang up.
UCONNECT – Switching a call to the handset for privacy, Press the Voice Recognition UConnect button on mirror and say Transfer Call.
NAV – Using with radio’s steering wheel buttons,
Note : When the steering controls are enabled, you will see a small steering wheel icon at the bottom right hand corner next to the time.
EVIC - To display codes, Turn your key on and off three times without starting the vehicle and at the end of the third you should either get the code(s) or "DONE".
- Holding down the middle Right button for about 2 seconds will enable the NAV screen.
- When prompted to hit enter select the middle Left button.
- Navigate through the menus with the up & down Left side buttons and select with the middle button.
