1 - 8 of 8 Posts
2018 GC HA
Hey crew!
I'm wondering if this part: 68310778AB
Will fit the lower bumper grill of my '18 HA with ACC.
I want the grill with the cutouts already in it for the front tow-hooks I plan on adding. Rather than dremel/cutting the existing front grille.
Will this fit my front bumper as it is with the cutouts so I don't have to do any modifications to fit tow hooks?
Thanks!
I would be concerned that the table is not accurate since it doesn't list the Summit and the HA uses the Summit fascia. AFAIK, the only way to accomplish the tow hook openings for the HA and Summit is to cut the existing fascia. But I could be wrong about that...
Well, if we assume that the Mopar listings are inaccurate (which would not be unprecedented) then we would search for Summit parts rather than High Altitude (the HA listing leads us back to the one previously found).
That gives us part number 68258570AA as Lower Grille, Center, with Tow Hooks. The other part number is 68258566AA Lower Grille Center without Tow Hooks.
2018 GC HA
Discussion Starter #5 (Edited)
Exactly, It's the summit fascia... that helps.
I foudn this part too which says it replaces the 68258566AA:
https://www.factorychryslerparts.com/products/jeep/grille-lower/GRILLE-Lower/13279794/68310778AB.html
at $33, it might be worth a shot, but that picture doesn't show what I'm expecting... however the full diagram points to the correct part. I'm not sure!
This one shows the right picture:
https://parts.lithiachryslermedford.com/oem-parts/mopar-lower-grille-68310778ab
EDIT:
Those are not for the summit fascia either, I found the one mentioned above... I will try it for $23!
https://parts.lithiachryslermedford.com/oem-parts/mopar-lower-grille-68258570aa
2018 GC HA
Discussion Starter #8
Did you ever add the hooks?
I did not... At this point I'm waiting for these :)
1 - 8 of 8 Posts
