1 - 20 of 30 Posts
2014 Jeep WK2 Diesel
I'm currently sitting on 265/50/20 on my 2014 Jeep Grand Cherokee overland 4x4. How big can I go without requiring a lift kit and no severe rubbing?
Jeep Grand Cherokee
Just wanted to give an update. Installed 275/55/20 BFG KO2 on a 2018 Altitude non QL. They fit perfect absolutely no rubbing. I highly recommend these tires they look bad a**.
JGC Summit
Here is 285/50-20 Cooper Zeon's on stock Summit. No rubbing and nice aggressive tread with a nice wide stance.
Reactions: Governor
hey guys,
so i have the 2011 laredo wk2 with v8, no QL, on 18x8 stock
want to change to the replica srt spider monkeys 20x9, i asked the dealer if 285/50r20 would fit, they were skeptical, i assume most of u guys run the 20x8 ? not sure if that is the stock 20 inch jeep wheel standard or not.. i wonder if the extra x1 difference in the wheel size would impact against the 285/50 for rubbing
any input would be appreciated, thanks!
hi all - I just wanted to throw out a quick thanks to everyone who posted their max tire size here and in other threads on the forum. thanks to all the good advice on here I just got 265/65/18 Falken Wildpeak A/T3Ws put on my 2015 limited, standard suspension, and stock rims with no spacers or modifications of any kind. No rubbing whatsoever. Nice looking tires, too.
Can you update us? Any issues with rubbing? I have a 17 grand Cherokee limited 4x4 18in rims and standard suspension as well. Really like the look of the 265 65 18 Falkens want to make sure that extra inch or so isn’t going to be an issue. Any thoughts and advice will help :)
no issue
no issues at all. no rubbing no matter how hard I turn them. great in moab.
GC TH
Some are running 32.1”, which is 275/65r18 w/o rubbing, so you should be fine.
I agree that 32.1 is the max tire size. You can fit 255/70/18 or 275/65/18, although you might experience a slight rubbing depending on the aggressiveness of the tire and tread design.
My buddy has 18" Fuel off-road rims with 265/65's. No rubbing issues according to him.
1 - 20 of 30 Posts
