Hey guys,
Just wanted to check with y'all before I do anything. The guy at the shop where I got my oil changed said if I use premium on long road trips that my mileage will be noticeably better. I understand the logic behind this, but isn't it frowned upon to switch between regular and premium?
I always thought of it kind of like feeding a dog. If you're gonna change his food, do it gradually or at least do it on empty and commit to it.
Octane is probably one of the least-well-understood things about a car that people need to deal with on a daily basis. It's also a good way to start a flame war. :slapfight:
I'll tell you what (I think) I know, and invite you to do your own research.
There is a common perception that high octane fuels have "more energy" or "perform better". But in reality the only thing that octane rates is how likely it is going to spontaneously ignite under pressure. Lower octane fuels will spontaneously ignite (without the spark from the plugs) at lower levels of compression than higher octane fuels. If you have a high compression engine and you put low octane fuel in, the fuel will likely ignite before the spark, which causes "engine knock" and will reduce performance.
However if you don't have a high compression engine, putting in higher octane fuel will do nothing other than drain your wallet faster.
So what you need to do is pair the fuel octane with the compression ratio of your engine. This is usually well-described by the manufacturer when they indicate what octane fuel they recommend using. If the manufacturer recommends 87 then you should use 87. Using 89 or 92 is not going to give you any better performance because your engine was designed so that it should not pre-ignite when running 87 fuel.
The 2014 JGC owner's manual indicates that the V6 should use 87 and the V8 should use 89. The manual also basically reiterates what I stated above by stating:
The manufacturer
recommends the use of 89 octane for optimum performance.
The use of premium gasoline is not recommended,
as it will not provide any benefit over regular gasoline in
these engines
(the above quote was specifically for the 5.7V8, not for the V6)
