1 - 8 of 8 Posts
2014 JGC Overland
Tomorrow getting second set of Nitto Terra Grappler G2 275/55/20 tires installed on GC Overland with quadratrac and Quadra-lift.
First set will still pass inspection but 2.5 yrs old with 81,273 miles on them (32k year), I can't believe how good they have held up. If I wasn't taking a weekend run up to upstate NY from VA I would keep a few months longer, but they should have a lot of snow so perfect time to freshen up tires.
The Jeep is 54 mo. old with 127,000 miles. First set of Nitto's put on in Aug 2015. I run a ton of highway miles and noise is barely noticeable for us.
I do rotate tire regulary every 3-6k miles.
Reactions: Tony42
Hmmm, mine are about 25,000 miles old and starting to wear on the outside shoulders (all 4 corners). Will be lucky to make it to 35,000 miles.
2014 JGC Overland
Thats stinks big time, not sure why our experiences so different. I really was religious in getting rotated at regular oil intervals. I keep air pressure at 36 and sides did wear more than middle, current installer says to put air at 40-45 and middle will wear faster than sides but I am very happy with results.
They are great in snow and off-road.
2014 JGC Overland
Got tires installed today, so smooth at 36psi, for trip up to NY Friday I plan to go up to 40 to see how it goes.
I have always had good luck with terra grapps on my Superduty's. Usually got around 35k to 40k out of them. To me that's great for a 10k lbs truck. Usually had 65 to 80 lbs in them and all were on 9 or 10 wide wheels.
Was actually thinking about getting a set for the winter months.
Yes indeed. We have plenty of snow for you this year. However the roads are clear with no slush, just wet.
any pics?
1 - 8 of 8 Posts
