Did you mean Duralast from Autozone or Diehard from Advanced?Nothing wrong with East Penn, but I'd recommend the Interstate H7 from Costco or the Advance Auto Duralast Platinum H7 which is identical to the Interstate. Just not an Optima fan for JGC's.
Changed it. Thanks.Did you mean Duralast from Autozone or Diehard from Advanced?
Duralast from Autozone. East Penn has been making their AGM batteries for a while. Previous to the WK2 battery, the one I got was an AGM for my 02 WJ.Did you mean Duralast from Autozone or Diehard from Advanced?
When you go on Walmart's site, to look for the battery, it's identical to an East Penn/Duralast. The ones in the store are different. 800CCA vs 850CCA. Bait and switch. So I went with the Duralast battery. I have no idea where or who makes the walmart ones now. Could be chinese for all we know.I went with the WalMart Everstart. Good pricing and warranty plus WalMart is everywhere.
I went with the Everlast. Says made in Germany on the battery. 4 year warranty vs 3 years for the others.When you go on Walmart's site, to look for the battery, it's identical to an East Penn/Duralast. The ones in the store are different. 800CCA vs 850CCA. Bait and switch. So I went with the Duralast battery. I have no idea where or who makes the walmart ones now. Could be chinese for all we know.
Are you talking about the OP size of H7 or the previous post with the H6? Autozone shows the H7 Duralast Platinum as 850 CCA and 1000CA. I recall that being the specs when I bought mine as well.FYI - WalMart, cleverly, uses 3 suppliers. East Penn, Exide and Clarios (formerly Johnson Controls). And the Duralast, like the Everstart are 800CCA. WalMart website shows 800.
I was just quoting the Duralast Gold and the Everstart Maxx for a comparison of 800cca. FYI - My 2020 V6 came with 650cca.
The diesel takes an H8 and pre-start/stop, like mine take H7. I should have been recommending the H6 Interstate AGM as you need space for the 2nd battery.The factory OEM battery I took in today said 650 CCA. The Everlast H6 says 760 CCA. My Limited with stop/start calls for an H6. I had all 3 batteries on the counter top at WM today. When comparing the H7, H6, and OEM, the H6 was exactly the same as the OEM size wise. Due to the small battery in the under seat compartment, an H7 won't fit. It's 1.5" or so longer and would not allow for the current set up and battery hold down bracket to fit. I read elsewhere you can buy the battery hold down for a diesel engine, use it, and a H7 would fit. I figured an H6 with more CCA than OEM should work for me.
I would agree but the dealership said big battery was bad and little battery was good. I’m thinking along your lines though, go ahead and replace the small one as well. It has to be cheaper by a significant amount, right?A little battery type confusion but we got there in the end😁.
So...its H6 for ESS, H7 for non-ESS and H8 for Ecodiesel.
ESS system back-up battery is Group 400. Evidently, common wisdom appears to be replace BOTH batteries.
Ahh...makes sense...the difference is likely Duralast Gold vs. Platinum (I have the Platinum).I was just quoting the Duralast Gold and the Everstart Maxx for a comparison of 800cca. FYI - My 2020 V6 came with 650cca.
It’s only use is to run the electronics when start/stop is active while stopped and engine off. How important is that for a feature I cannot stand. Just push the button and avoid it all together??I've seen prices on the group 400's from $60 to $150!
