After dropping a valve seat I bought 2 brand new cylinder heads from power torque. The install went smooth. Replaced timing set and all gaskets. Engine starts up a seems to run great. Took for a short test drive and after a few minutes the oil pressure dropped to nothing I pulled over and popped the hood and on the top of intake manifold and underneath my k&n cai it was shiny like something had been sprayed on it. I checked around the cylinder heads and all I could see is a small pool around the coil for cylinder #2. (4.7l v8). I don't see how it could be leaking from the head and spraying up to the top of the intake manifold. I replaced the valve cover gaskets and maybe it's leaking from those but I don't think they would cause the drop in oil pressure.
randomly the oil pressure will jump back up to normal only to fall back to 0 shortly after.
