We are happy to introduce our own Xtreme LED Mini series of replacement light bulbs. Our state of the art bulbs feature:
- An aluminium body for optimal thermal mass to give your lights a longer life, even through prolonged use or high temperatures.
- Spherical light output to ensure light is given off in the best pattern possible.
- Available in amber, white, and red.
We have engineered this impressive series of bulbs to give you long lasting, and great quality light.
Available in the following fitments:
1156, 1157, 3156, 3157, 7440,
7443, R5W
Discussion Starter #2
Are you excited? Well you should be, because our Xtreme LED Minis are finally here! Available for shipping out Now - get your order in and be one of the first to try our new line of LED bulbs, perfect for Tail Lights, Brake Lights, and Turn Signals.
Not sure about whether you need the "CANbus" option? This is designed to get you a pair of our 11 Ohm Electrical Load Resistors, which will take care of "Light Out" error codes from your vehicle and deal with Hyper Flashing problems with Turn Signals. Check with your vehicle to see if you have an error code indicator - if you do, you will want to get the Resistors to go with your bulbs, and you will definitely need them if you are replacing Turn Signals. Keep in mind that you need to be able to mount the Resistors to metal, as they get hot while in use.
Check out our Vehicle Lighting Guide if you aren't sure of the bulb type you need for your Jeep, or get in touch with our knowledgeable and friendly staff more directly by phone (1-877-522-2701) or email if you have any questions.
~Robert
They're here and they're so real you can almost reach out and touch them!
Available for shipping Now: Red/White/Amber lighting, in a variety of different fitments.
Happy weekend, Everybody!
~Robert
