So the code popped- disabled remote start and ECO mode- and I threw a new solenoid at it, no help.
Found my VOM and am getting no power at the connector (Blue/white?) good ground on the other (Blue?).
I thought this ran on switched ground.
Where do I go next? I'd hate to shotgun a PCM without verifying something.
Discussion Starter #2
Well, I busted out the tone generator on the blue/white and got signal everywhere.
Checked resistance to ground at 200k, got 166K. Disconnected PCM connectors, 2nd one killed it.
Found the pin, good continuity. Yay, it's not a bad wire, Boo, it's the PCM.
Ordered PCM from FS1, took a few days to receive, installed, cleared nuisance codes, it's plug and play.
No issues. Fix dit.
