1 - 20 of 144 Posts
2018 Limited 5.7 HEMI
With all the questions all over this forums in regards to suspension it only seems right that we should just have a knowledge thread. I would like to update and keep it fresh with latest info so I look to you guys/gals for info on what you have done as well as a picture of your final product. Lets go with a few simple questions and we can start building a little database of what works and how it looks.
Mine:
Year: 2013
Wheel Size: 17"
Springs(SRT or NON SRT): SRT
Which ones: MOPAR
Measurements(center hub to lowest point of Fender): Front: 18" / Rear: 18 1/8"
other suspension parts: OEM
Did you get an alignment: Yes(Dealer)
Back within Spec?: Yes
Discussion Starter #2 (Edited)
lonebull's 2017 limited with SRT Stock Rears on 22's
Year: 2017
Wheel Size: 22"
Which ones: Stock SRT Rears only
Measurements(center hub to lowest point of Fender): Front: 20"/Rear: 20"
other suspension parts: SRT stock Sway&Links
Back within Spec?:
Jeep_addicted's 2012 Laredo X QT1
Year: 2012
Wheel Size: ?
Measurements(center hub to lowest point of Fender): Front: / Rear:
Back within Spec?:
Discussion Starter #4
I'll try to scrub some of the other threads that might have some info we can place in OP and add link to the post. But I'd prefer if the exact details are put here so I don't mess it up.
Added measurements of my Post Spring install from hub to fender as well.
here is how the jeep sits now after installing 2017 SRT rear springs only, keeping the front 2017 stock springs.
also switched out the 2017 stock, rear only sway bar and links, for 2017 SRT oem parts.
I haven't changed the stock shock setup.
front and rear heights are now level and match perfect. no more rake.
both front & rear have the same measurements 34" from the floor to fender, 20" from center hub to fender.
22"x 9" wheels
2012 Laredo X QT1
In my case my front end got higher becasue my car suffered from the bent spring issue where there is a TSB about it. So for years the front end was pretty low. People would ask me if it was lowered and I would say no it's stock but is sat lower than all the other WK2 of the same age.
My setup:
Shocks and struts : Bilstein 4600 series stut up front and shocks in the rear.
Springs: 2014 OEM SRT springs (NON towing pack)
The rear did get lower and the front raised up about an inch or so, The result is a Level Stance.
Discussion Starter #9
Thanks guys, adding details as they are posted... if possible please update your original post with additional details and pics. I am linking to your post and so as the thread gets longer it will make it easier to find pictures if they are all with in the same post.
Thanks again!
Discussion Starter #10
Hmmm i can no longer Edit my OP :( well hopefully one of the Mods can update the second post for us with additional rides! or just keep updating the thread with similar format as i started above.
Discussion Starter #11 (Edited)
Johndave's 2011 3.6l
Year: 2011
Wheel Size: 22"
Springs(SRT or NON SRT): NON SRT
Which ones: Eibach Pro Kit
Back within Spec?:
ksufan7227's 2015 GC
Year: 2015
Wheel Size: 22"
Which ones: Road Magnet mid drop kit
Did you get an alignment: (Dealer)
Back within Spec?:
BrandonMorris 2012 GC
Year: 2012
Wheel Size: 17"
Which ones: Eibach Pro kit
Back within Spec?:
Year: 2017
Wheel Size: 22"
Back within Spec?:
Year: 2012
Wheel Size: ?
Back within Spec?:
Wheel size is OEM 20 x 8 ( running 265/50 VR 20 tire)
Rear sway : OEM
Rear Sway links: Black OPS shortens version.
Front sway : OEM
Front sway Links : MOOG problems solver (claimed to be improved over stock design)
No Alignment done.
Discussion Starter #14
Unfortunately i cant edit my post anymore.... sorry about missing that bro :(
Hopefully Scott will hook me up to edit some post, or maybe he can move them for us into the 2nd post. I thought i was going to be able to edit my post so was going to keep things updated that way but no dice.
Mine:
Year: 2013
Wheel Size: 17"
Which ones: MOPAR
What is the part # for these? debating between these or just doing standard oem srt8 rears on my 15" limited.
75th Anniversary
I think ksufan7227 had to revert back to stock springs, because the shocks gave out.
Discussion Starter #20
Im curious if even with the BWoody suspension correction part they were unable to get it back to spec? Or if it was just with stock adjustments that they had trouble, i believe that with BWoody you should be able to get back to within spec.
@jaywk2, im sorry man i am not sure which ones are the right ones but i know one of the threads above, a gent bought the 69 dollar coils and they were in fact the SRT Stocks.
@all, can you guys post your readings if you are still on Stock suspension? Like an idiot i did not measure before installing the Mopar springs :( and now im wondering how much the front actually went down. Year/model/height from center to lower part of fender.
Thanks!
1 - 20 of 144 Posts
