2014 Jeep Summit
Hey guys so anyway my engine is running real ruff and I decided it was. My oil which came out really thin and worn and dirty at 3000 miles so I decided to flush my crank case I put a garden hose in my oil fill hole and turned it on and opened drain plug and turned car on to flush the engine, it didn't work so well after about 20 seconds it got really rough and sputtered so I figured it was probably cleaned out so I took the hose out drained the rest of the water and than I put a new fram filter on and put in some super tech oil from Walmart and now my engine runs like crap, any advice? By the way the filter was only $2 and the oil was $1.99 a qt any help thanks
APRIL FOOLS!!!
Lol
This never happened, I'm not that dumb
Let's Roll
I was going to suggest checking the headlight fluid. a good quality headlight fluid will make you car run much smoother and get better mpgs...... I would suggest royal purple headlight fluid. it will work great until you hit 3k, then it will run like crap and your mpgs will plummet lolololol
69 Camaro
If it's riding rough; you might want to put some authentic "racing air" in the tires....
