1 - 20 of 25 Posts
I noticed this grime on the front of the engine when changing the oil this weekend. Looks to me like oil is weeping from somewhere onto the front of the motor, but I can't find from where. My rack & pinion is also leaking on the passenger side around the rubber boot. I first thought the oil from the boot was blowing up onto the front of the motor while driving, but if you look at the pictures it appears to be confined to a certain area on the block and there is no grime on the parts mounted out in front of the block...? Dealership said R&P is $1300 to replace and I should wait because the leak is very small. They also said that the grime on the front of the motor is normal road and belt grime. Anyone else have this problem?
May 2011 build / 46,000 miles / Also had the drivers side head replaced.
My 2.5 year old Pentastar doesn't look like that at all! It could be an oil leak from the oil filter. Make sure there isn't a stuck o-ring.
2014 WK2 Overland
I've got waaaay more miles on my 3.6 and I can honestly say that it's as clean as a whistle. That leak on yours doesn't look all that recent. How long ago (miles) was the head replaced? Did you visually inspect after the head swap was completed?
2012 GCO
It doesn't look like a leak from above, since it gets nastier further down. It looks like oil is being slung from your crankshaft seal.
Or it could be from the steering rack, and picked up by the crank pulley somehow.
The best way to diagnose a leak is to clean the area and then monitor it periodically.
The crankshaft seal would be my guess also. I removed the engine bay bottom cover to get a better look up in there. There's no dripping oil and the crank seal area is covered in grime like the rest of the motor. The dealership says the powertrain warranty will only cover this leak (from where ever ) when there is an actual oil drip....weeping oil is not covered.
I plan on degreasing the motor this weekend and I'll keep an eye on it from there.
I have a similiar leak in the same area but not as much. I took it in today and they said its leaking but not sure where. They need 2 more days to find out. My 2011 JGC only has 13,000 miles and tey said it would be covered under warranty. I will let you know what they find out.
My 2011 Grand Cherokee is doing the same thing (30k miles now; first noticed after purchase at 24k miles). The dealer acknowledged that it's not normal, cleaned the engine and added a dye to the oil to find the leak. After 3k miles there was no leak. Another 2.5k miles and its coming back. I'll have it back in for an oil change in a couple hundred miles and intend to bring this up again. Any suggestions as to where to steer them would be appreciated. I'll post my results after I see the dealer again.
My dealership thought it was coming from the timing belt seal and did the work to replace that. Less than a couple thousand miles and it appears to be coming back... Maybe I need to push them to replace the crank shaft seal next...
Thanks for the feedback!
I have the same condition as sullivan4109 pic shows- I dont have warranty- so what would everyone suggest? get my own dye kit/light?. I see nothing obviously leaking, if it is the front crank seal hows it getting from main crank pulley up to the alternator?
wait for it to get worse? its dropping oil onto belly pan/steering sector area too-just enough to get it greasy/dirty- thanks
Back in October I took my Grand Cherokee back in for service. The dealership replaced the whole timing cover with the explanation that they had replaced the seals a couple of times with no positive results. They felt the cover itself may have been porous and allowing the oil to leak. Problem seems to be solved at this point; all covered under warranty. Good luck, guys.
Not sure what it would have cost out of pocket, although I remember thinking "Thank goodness it's covered".
I'm happy to report that after the work there is still no leak.
Unfortunately my 2013 with 19k miles is exhibiting symptoms of an oil leak in this area. It doesn't look nearly as dirty as OP's pictures, but the alternator bolts and area in between are covered. I'll be bringing it to my dealer's attention at the next oil change.
Are oil leaks covered by the power train warranty on jeeps? They were with my VW.
I just got my jeep back from the dealer.
Problem they reported: found timing cover leaking oil and coolant.
Fix: gasket,timing chain or belt case/cover replace.
Only thing is the dealer didn't clean the oil off the front of motor and alternator. What is the best way to clean this?
1 - 20 of 25 Posts
