Hello all. First post here, so bear with me. Up until recently, I've had no issues with my 4.0L WJ. Although it's a 2002, it has "just" 128K miles on it. This Monday (it was cold here [for us] this week, in the upper 40's on Monday), I heard a very noticeable whooshing sound coming from the engine. At the same time, I also noticed that the idiot pressure gauge was reading all the way high "H" when cold, and staying there over 1K RPM for about 30 minutes. After it warmed up, it want down to mid gauge at idle, and about 3/4 to H when driving. This is very abnormal, as the pressure usually reads just above mid point most of the time, and varies little.
My first thought was that the oil pressure sender was bad, EXCEPT for the noticeable whooshing sound. To me, it sounds like a bad restriction, like high pressure water being sprayed under water. Some of the few postings I've read, mentioned that the oil pump was in bypass. I'm quite familiar with hydraulics, and that to me is the most plausible explanation.
The concern I have is if there's a restriction that's causing a high pressure bypass condition, than I suppose it's possible that some parts in the engine are seeing low oil flow/pressure, which can make for a bad day.
One note. I'm the original owner, and have always used 10W30 oil for the engine, except the last change, where for the first time, I tried 5W30. That was 2300 miles ago since I last had the oil changed. I don't know if that has anything to do with the current problems, but its a data point.
If it was just the sender, that's something that seems easy enough to do, but an oil pump means the repair shop, and the ever present $500 minimum repair cost (for anything it seems).
Any suggestions?
Thanks,
Bill
Any suggestions?
Thanks,
Bill
