What kind of oil temps are you all seeing?
Mostly in the low 70s around here and and I went up
to about 226 in city driving today. My Charger Hellcat
usually runs about 20 degrees cooler, but sensor might be in
a different location.
Trackhawk
"IF" I am recalling correctly, mine is running about 220 to 225 under normal highway driving. I'll try to remember to check next time I'm out to be sure. I know I saw my oil pressure over 75lbs right after I changed the oil recently.
Thanks, that's what i'm seeing on both also.
