1 - 2 of 2 Posts
Looking to get an ome lift installed in the northern VA area, any suggestions? It seems easy enough but I just don't have the time/place to do it myself.
I'll probably end up running the stock 245/65/17s for awhile on my 2010 laredo so it might look a little funny until I get a bigger tire/wheel (my current tires are fairly new and I still need to do some more research on size to get something that doesn't require any additional mods for clearance, I suspect the dealer can reset the speedometer if I do go up in size). How much lift will I be getting for the medium vs heavy (I still want to be able to get into some of those low hanging downtown DC garages)? I don't have or plan on adding any other accessories but do have the heavier 5.7 hemi. This is my daily driver also so I'm not looking to change it too much, just want some height.
I think I've ruled out the budget spacer lift.
Discussion Starter · #2 ·
I'm looking at getting the lift and then coming back and adding 265/70/17s Michelin M/S2s on 17" Platinum Marathons (black) from tirerack. Does anyone have any experience with either of these? Trying to see if I'll need the pinch weld mod or add wheel spacers...
1 - 2 of 2 Posts
