I wasn't sure exactly where to put this, so I guess this will do! *
This is my build thread for my hidden winch build. *I originally had it on another forum, but figured some of you would enjoy it as well! *I started taking measurements and drawing up ideas and plans back in Dec of 2010. *Then started cutting out the plate steel in Feb 2011. *And finally finished the complete build in May 2011. *
It all started from seeing the original Mojave and the hidden winch system that the people at AEV made for it. *
The only problem I had with it was that they mounted the winch up side down. *This means that when you get stuck and need to use the winch, you have to reach under the bumper to access the clutch lever. *That was not something I was wanting to do, because if you are stuck off road reaching under the bumper can get difficult at times. *Other than that I liked the design. *Made out of .25" steel and replaces the factory crossmember.*
So I decided to make a winch plate but mount the winch right side up. *I started by making measurements of my front end.*
I wanted to try and reuse the 4xGuard Matrix and do what I could to keep it intact incase I ever decided to sell it. *
From my measurements I made a quick sketch of the base of the plate. *It will go under the frame and use the four tow hook bolts as the initial anchor point. *
