Thanks, but this mainly talks about the anti-gel ones, I am more interested in the ones like Hot Shots EDT or Archoil's AR6500 Diesel Treatment.
You really should watch it for the lubricity and corrosion tests. Anti-gel was but such a small part of the video.Thanks, but this mainly talks about the anti-gel ones, I am more interested in the ones like Hot Shots EDT or Archoil's AR6500 Diesel Treatment.![]()
...apparently I have a short attention span.You really should watch it for the lubricity and corrosion tests. Anti-gel was but such a small part of the video.
Best thing you can do for these motors. Which tune did you go with?I am thinking more along the lines of helping the crank bearings go a bit longer as this seems to be a weak point - at least with the 1500 folks, I keep seeing posts about bearing failures with them.
I do change my oil every 10,000km (6200 miles) thinking it can't hurt - having the EGR turned off seems to have increased the range on the oil life indicator though.
My mechanic, suggested I use Diesel Clean, which is recommended by Cumming, after I was having a lot of soot build up and regens (pre AEM updates). I put it in every other tank, and it seems to help. Could be my imagination.Is anyone using them and/or what is your opinion?
I have heard people like using Hot Shots EDT on other vehicles.
