1 - 12 of 12 Posts
Went to leave after work today and right when I started the Jeep I immediately got the MIL. Did the key dance and got P0152 - O2 Sensor 2/1 Circuit High.
I've got the negative battery cable off it right now for about 10 minutes to try and reset everything. If it comes back, guess I'll buy a new O2 sensor.
Sorry to hear. Good luck...
Jeep SRT8
I remember you saying that you were running 93 octane on the 91 Superchips tune... if that's true, you should run 91 octane for the tune or else you'll continue to get the code.
91 octane is not offered around here. it is 87/89/93.
I had been running 93 on the 91 tune for probably 2 weeks/1000ish miles before this happened - I think it would have popped up earlier if running 93 was a problem?
Jeep SRT8
You could be running rich.. either that or your sensor took a dump.
We'll see.. the MIL went away after disconnecting the battery for a little while. The truck has been running fine.
Long Live the Grey Ghosts
manual says:
When Monitored:
O2 Sensor Heater Temperature is greater than 496° C (925° F) and battery voltage greater than 10.99 volts.
Set Condition:
The Oxygen Sensor voltage is above 3.9 volts for 30 seconds. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
(K43) O2 2/1 SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
(K902) O2 RETURN UPSTREAM CIRCUIT SHORTED TO BATTERY VOLTAGE
(K43) O2 2/1 SIGNAL CIRCUIT OPEN
(K902) O2 RETURN UPSTREAM CIRCUIT OPEN
O2 SENSOR
PCM
_____________
i would make sure you didnt melt a wire down there before going to much further.
Discussion Starter · #11 ·
manual says:
When Monitored:
Set Condition:
Possible Causes
O2 SENSOR
PCM
_____________
The code hasn't been back since I cleared it, and the truck is driving completely normal.
Discussion Starter · #12 ·
Well one week later and a trip to NC and back and the code hasn't come back. Guess it was just a one time fluke deal.
1 - 12 of 12 Posts
