1 - 2 of 2 Posts
Hi guys, my WK1 was sideswiped a few weeks ago, dealer redid the paint & after my mom picked it up, there was a noticeable shudder in the cabin. felt like a misfire & the exhaust smells of gas. i do the key dance & i got P0301 at first with P2302/8 following a day later.
P0301-Cylinder 1 Misfire Detected
P2302-Ignition Coil "A" Secondary Circuit
P2308-Ignition Coil "D" Secondary Circuit
ive removed the ignition wire into the #1 cylinder with no change, so there is something definitely up with it.
please help!
Discussion Starter · #2 ·
Ok just figured i'de update this for someone with a similar problem.
problem sorted itself out after adding a bottle of injector cleaner.... :eek: ...
based on that ,to anyone coming across a similar issue, ide say ...
--> if left non-running for a while, injector clogging is definitely a probable issue & a bottle of injector cleaner was a real cheap & easy fix.
Cheers all!
1 - 2 of 2 Posts
