... OR, are we limited to 1 set of pages?? Off Road pages OR Performance pages?
Has anyone been able to get the performance pages on a 2018 or newer non SRT?
I have the 2020 Jeep Grand Cherokee Trailhawk.
I am using the OBD JScan app from the Google Play Store, a Cable Adaptor for Chrysler Programming Cable 12+8 Connector to bypass the Security Gateway Module, and a OBDLink MX+ to read the CANBUS System.
I was able to Activate the Performance Pages, but I can't see it in the Uconnect app screen, and there is a blank space where the Performance options would be in the dash.
The answer is no.... OR, are we limited to 1 set of pages?? Off Road pages OR Performance pages?
The answer is no.
Because the 2018 and newer Jeeps Infotainment system is cloud based, FCA and control what apps we have available on our Uconnect systems.
2017 and older, you can have both, the Offroad pages and the Performance pages. They are already loaded in your system, they just need to be turned on.
I looked, I can't find the off-Road Pages? I can find the Performance Pages, but not the Off-Road Pages... sorry?how do you turn on the off-road pages on a 2016 summit? With JScan
I did the performance pages “procedure” thru JScan and it came up for a minute and now it’s gone and no matter what I do it never stays. I just feel it’s wasted timeI looked, I can't find the off-Road Pages? I can find the Performance Pages, but not the Off-Road Pages... sorry?
Something to do with Cloud Based Applications. Uconnect performs a check every time the vehicle is started to ensure that you only have the Apps available that originally came on your specific Jeep.I did the performance pages “procedure” thru JScan and it came up for a minute and now it’s gone and no matter what I do it never stays. I just feel it’s wasted time
I'm having the same issue with my 2017 hemi trailhawk. I activated the pages and just got blank options in the cluster, and the SRT pages loading screen on my main infotainment. Never fully loads. I tried doing it several times to no avail. I saw something that said you needed to enable the vehicle as SRT, but when I did that the system went haywire and had the service 4wd and no forward collision etc. Reverted it back and everything is fine, but still no performance pagesSomething to do with Cloud Based Applications. Uconnect performs a check every time the vehicle is started to ensure that you only have the Apps available that originally came on your specific Jeep.
If you didn't buy it from Jeep, or it didn't come with your Jeep, you can't have it (So-to-Speak).
I thought that it applied to 2018 and newer vehicles only...
У меня такая же проблема с моим hemi trailhawk 2017 года выпуска. Я активировал страницы и просто получил пустые параметры в кластере и экран загрузки SRT-страниц в моем главном информационно-развлекательном центре. Никогда не загружается полностью. Я пытался сделать это несколько раз, но безрезультатно. Я видел кое-что, в чем говорилось, что вам нужно включить автомобиль как SRT, но когда я это сделал, система вышла из строя и включила сервисное 4wd, без прямого столкновения и т.д. Вернул его обратно, и все в порядке, но страниц производительности по-прежнему нет
[/ЦИТАТА]
Greetings to all! The same problem " Performance Pages doesn't work? " " My machine is WK2 Trailhawk 2017 , Uconnect is installed from WK2 2019. What could be the problem, the firmware is the latest , the rest of the applications work, including OFF ROAD PAGES.
