Any tips on getting the pitman arm off the steering gearbox? I'm replacing the gearbox and the pitman are will NOT come off the damn thing.
I currently have the gearbox out of the Jeep, but NONE of the auto parts stores in my area have replacement pitman arms.
I rented a pitman arm puller from O'Reilly. I put that on and cranked down on it. Unfortunately the bottom of the puller is rounded, so you can NOT use a 6-point socket to turn it (have to use a box end wrench). So I took a 17mm wrench and turned it until I could turn it no more. Then I took a hammer and hammered on the bottom of the puller and pitman arm (attempt to jar it off).
After that didn't work I took out the 4' cheater bar and put that on the wrench. I turned that until it started to strip the bottom of the puller. Literally, the box end wrench couldn't hold onto it and stated to deform 2 of the 6 points. So again, I tried to jar it with the hammer with no luck. Then I tried to apply heat and again with the hammer. Piece of crap still wouldn't budge.
Then I attempted to remove the puller...........same result as trying to tighten it.
So I said screw it, I'm going until it comes off or something breaks. I pulled out the pipe wrench and grabbed onto the bottom of the puller and kept on tightening. I broke the damn pitman arm puller. WTF!!!
So it's a long shot, but does anyone have any other ideas? I'm down to either buy a new one and have my DD down until it arrives or take it to a shop to have it removed.
