2014 Jeep JKU. The driver side O2 sensor cables got loose from the zip tie , and they were both wrapped around the steering column... When I turned the wheel, both harness came out of the plugs as photo shows. So I can't find a matching color code diagramm to see what order I have to plug those back to the white plug. On the plug I have numbers as 1,2,3,4 and looks like the 4 colors are blue with green stripe, brown with green stripe, black, and brown with purple stripe i think..
So hopefuly someone can help me to match what color goes where , than I will need help to figure what sensor cable to plug to witch harness plug? From engine i will have a white and black color plugs, i have no clue which goes to the sensor is closer to the engine, and the sensor is further down?
