-Easy to switch between each color – simply turn OEM fog switch off/on - normal cycle: White - yellow - halogen - flash/strobe
-BRIGHT – this is not just a novelty bulb
-COLOR MATCH - these match our LEDs/HIDs in 5500K White mode
-HYPER YELLOW - these are a true hyper yellow mode you normally see with yellow lamin-x covering the lens **this is NOT a cover around a bulb or a cover on your lens - this is brand new LEDs that are a super hyper 3K yellow**
-SAFE – more light on the sides and down the road when dark or in bad weather conditions
****INTRO PRICE****$110 includes FREE UPGRADED SHIPPING (RETAIL $144.99) Simply email [email protected] for an invoice
This has 3 different colors and strobe/flash modes:
-The Hyper Strobe / Flash – this does not simply "flash" but has a strobe/flash pattern like an emergency vehicle - you can choose between 4 different modes - video of mode 1: https://www.instagram.com/p/Bpjxc_ajyaS/
****Do not miss out these are going fast**** This Into Price ENDS IN approximately 2 weeks!
-Also including 20% off anything else you purchase – only valid when you purchase fogs
-They have a ship date of December 17th-19th with FREE upgraded priority mail shipping within the US only. These will most likely arrive before Christmas but currently no guarantee (sub to this thread for updates)
-THESE ARE BRIGHT! You might have seen the novelty fog LEDs that can turn yellow/white on amazon and ebay by the thousand that don't provide much useful light, trigger errors, die quickly, or simply don't work correctly. Our new model fixes every issue you might've seen and simply works.
-These produce MORE LUMENS than many standalone single color white fog LEDs on the market
-Not only are these great for safety, daily use on dark roads and bad weather this will amaze at any car show and you will have your friend asking how did you do that and where can I get those anytime you use these fogs!
*Please note these ARE error free but in strobe/flash mode they can trigger an error in some car models – errors WILL clear once you go back to a solid color.
UPDATED FAQ
Is there a lifetime warranty?
YES! As always this comes with a True Lifetime Warranty!
Will your fogs keep changing colors if you use them as cornering lights?
The answer is no as this only changes by turning your fog switch on/off. If you are using your fogs as cornering lights it will always be the default color of white.
How does this work with the coming home feature?
This works just like OEM. It will always be the default color of white.
What if I have the yellow feature on and turn off my car; will it then go into the next color when I turn it back on?
The LEDs will always revert back to the default color of white. Then simply turn the fog on/off for your desired color: yellow/halogen or strobe/flash mode.
Can these turn 360 degrees?
Yes, these are a fully adjustable design so you can turn these 360 for the best beam angle.
Are these as bright as your single color de360 fogs?
While not as bright lumen wise it comes very close - many people that have switched to our single color white to our dual color yellow/white LED fog kit have not noticed any difference in visibility. As we said this is NOT a novelty yellow/white you normally see. This is meant to be used to help with your visibility.
Can you bypass the strobe feature?
Yes, this works when you turn the fogs on/off quickly. If your next mode will be strobe simply shut off the fogs for a few seconds and then turn it back on and it will go back to the default white.
Some more fun shots - in the rain:
White / the super hyper yellow - this will be a hyper lamin-x yellow without the cover!
And switch back to clean white:
Check all laws - flashing yellow/white could be illegal and should never be used while driving.
It should only be used:
-car shows
-showing off to friends
-emergency situations
These are error free BUT if your car triggers errors you could need extra resistance. We sell them separately if your car has an issues - these are a plug and play model that doesn't require you to attach it to metal. But these are tested to be error free in 99% of car models.
I have been running these for about 4mo now and I love them. Very bright and a crisp cutoff. Only issue I have had is when the auto high beams kick on and off in less than 2sec it will change modes. Went in and changed the setting with my Tazer so the fogs are always on and problem solved. Just something you will need to pay attention to.
I can't say how they compare to the HA fogs but the install requires removing the front bumper fascia. Very simple, there are several how to's on YouTube.
Thinking about adding some aux lighting behind the grill(s) has got me thinking about the different and best ways to wire it. Would love to hear some thoughts on the topic.
A significant use I would have for it (in addition to off-road, emergencies, etc.) is dark country roads/highways at...
I have a 2018 wk2 altitude and have the stock halogen lights which are terrible at night. I’m looking at getting LEDs for both high/low beams and fog lights. Any recommendations on what brand/brightness to use?
My wife has a 2017 Jeep Grand Cherokee Overland. Overall we really like it, but there is one thing that annoys us... it has bad side vision at night. On normal roads, highways, etc it is fine, but we live in Colorado in the front range, and we have some very twisty roads with switchbacks. They...
My 2014 Summit came with HIDs and was disappointing when new. Now the outer headlamp plastic has become hazy (in a ring where the light is focused) and the light on the road is even worse. I'd like to replace the entire units (to get rid of the haziness) and to convert to high power LEDs, but...
I installed some Rigid SS-Pros in Driving Pattern, and used an old wireless controller I had installed in my last few Jeeps. The picture with the lights on outside is only the Rigids on, no other lights. I didn't adjust camera settings or anything, just too the pics with my phone. They are...
