61 - 69 of 69 Posts
I work at a gas station in NJ so I pump everyone's gas. 99% of the grand cherokees that come in that are 2017 and up ALWAYS click off and give me a problem. I'm pretty sure it has something to do with the design of the fuel tank or the neck of it. So when I see a grand Cherokee pulling in for gas, I just expect it to click off now. 90% of the time I can flip the nozzle upside down and get it going. But there are a few stubborn ones that I have to hold the nozzle and pretty much go penny by penny which takes forever.
Just filled up my wife's Jeep Grand Cherokee Laredo '17... had the same issue with the gas pump shutting off every couple seconds. She hops out of the car and spins the nozzle upside down and it works fine... I look at her like she is crazy and she shrugs and says that's just how it works and it happens at various gas stations. I couldn't believe it ... so my ensuing search brings me here. Sounds like a design flaw on the vehicle. I guess it is good to know it isn't just us.
BUCKE77 said:
Most of the time it's the pump and not the vehicle.
Agree, I've had this happen a few times with my 2014 Overland. Doesn't occur at every fill up.
It's both.... ....that's why it doesn't happen to one vehicle at every gas station... ...and at one gas station with multiple identical pumps, its not happening to all the vehicles pumping at the same time....
The pump shuts off as soon as the tiniest bit of liquid hits a port on the tip of the nozzle.... ....so if the fuel is splashing as its pumped down the filler tube, it will shut off the pump.... ...the size, shape and bends in the filler tube and the nozzle itself and how they fit together, as well as the pressure set at the pump will all effect if it will splash fuel or not.....
Twisting the nozzle to a new position changes that fit and is why it often works if the pump keeps shutting off.....
I've got the same problem with a 2018 JGC Summit. I have approximately 45000km, and just recently ran into this issue on the weekend for the first time. I wrote down the filler tube part number that was referenced earlier in the chat, in case I have to bring into a dealer. I'm also gonig to try looking down the tube to see if some piece of plastic isn't stuck down there - like someone mentioned. I thought I had tried filling it upside down 180 degrees when I was stuck at a pump, but perhaps I only flipped it 45 degrees, and not 180 - but regardless flipping it 45 degrees didn't help . I'll try that later when I have to fill up. I too was stuck at a pump, pumping pennies into my tank, so I could fill it completely. What a PITA!!!!!
One tip you can try is rotating the nozzle upside down, no joke.
I was having the same exact problem with my '15 Overland at Costco. So far i'm 3 for 3 without having to squeeze the lever over & over again since I found out about it here.
this just fixed that same problem on my 2018. thanks dude
'15 GC Overland
No prob. Lately i've been rotating the gas nozzle to the 3-O'Clock position which been working great as well. So you can try that too and see if that works for you.
Anyone else having this problem on their 2017 grand cherokee?
I had a 2015 and everything was 100% fine --
Just got a 2017 GC and I CANT fill the tank without it "clicking" and stopping before having to squeeze the gas handle again. I can usually only get to $10-$15 of gas before it gets so frustrating and I just have to give up. The pump just clicks off as if the tank is full, but its not.....
Am I using the wrong angle putting the nozzle into the gas tank or something? Has anyone else experienced this? This happens to me at every gas station I go to since I got the car....
Any help/advice would be greatly appreciated.
Thanks!
Mine does this every time. I’m getting new gas vents.
2017 GC Trailhawk
This has been driving me insane on my 2017 GC TH. I have problems at the gas stations that are most convenient to my home and work. I can work around it by using the the lower setting on the pump and by the "just the tip" method, but I shouldn't have to fuss like this just to fill my vehicle. The dealer was no help, and of course it worked great at the gas station next to the dealer. I'm going to try this 180 degree thing. If any learns of TSB or some other fix for this please post. I'll post anything I find.
Have the same problem every time I fill my 2018 High Altitude. Such a pain! Will try turning the nozzle trick next time.
61 - 69 of 69 Posts
