1 - 2 of 2 Posts
brand new to jeep garge owned this for jeep for 6 years and no problems but last month started what seems like a front diff issue? 2005 jeep cherokee limited turn only to the right seems to hitch like front is locked up, so being only one side i figured cv. got it on the lift seemed fine. took in it to my buddies repair shop on there lift can barely turn front wheel while holding the other front wheel, go to the back and do the same procedure and the rear tire turns alot easier. while on the lift with key on tranfer case side motor is clicking, checked codes next c141 c140a u1120 p101 and u101. ok so were do we start ive heard of change front diff but the transfer takes out the new diff? ive heard change out the seloniod and harness to front end? i need some help with this one thanks Darrin
forgot to mention this as well may not be related but could be? turning to the left hard like u-turn or doing circles the jeep stalls out but if you turn the wheel back fast enough it restarted? then i noticed at traffic lights the rpms seem to fluxuate like it trying to find itself, but its only 200 rpm variance again any help is greatly appreciated
1 - 2 of 2 Posts
