1 - 20 of 38 Posts
Can someone please explain the technology behind the push button start. If you start the engine as instructed (foot on the break, push the button with the key fob close by) but then walk a distance away from the vehicle with the key fob. Will the engine automatically shut-off, since the key fob is not near...or will the engine continue to run until it is manually shut off?
There is a "Tow Mode" on the 4WD knob-if you have 4WD anyway. I think you remove the faus key from the fob to release the knob.
I have started mine from about 100 yards and the 4th floor of my office. Yes it will run til it dies but it cannot be moved until you have the key within I think 3 feet from the ... sensor(?).
I need a REAL key,,,, anyone know how to get one for FREE-at least one should have been supplied.
Discussion Starter · #6 · (Edited)
So....it just continues to run. If you forget to manually turn it off, it will just idle and run? Shouldn't there be some safeguard that if the vehicle is running (idle) and the key fob is not within xx yards, the vehicle turns itself off after xx minutes? Why would someone want the vehicle to idle for an extended period without being "near" it? There may be off-road reasons I'm not aware of, but for the normal driver who does not take the vehicle off-road, wouldn't it make sense to have it turn off automatically at some point?
D you mean the one inside the fob?
2014 Grand Cherokee
From the manual, it will only run for 15 minutes at a time using the remote start. If it shuts off after the 15 minutes using the remote start, remote start can be used again for 15 minutes but will not work a third time until button in the car is used. If fuel is low is says that remote start will only work for 10 seconds, but I believe I've read from some users that it won't work at all if it's low. Also, if the doors are unlocked when you use the remote start the doors will lock. There's a few more things in the manual about remote start, but I think those are the bigger points.
Maybe I was not clear in my initial post...I'm not talking about starting the vehicle remotely. I'm wondering, if you start the vehicle normally (by sitting in the drivers seat and having the key fob close-by) and then forget to manually shut off the vehicle (by pressing the push button), I assume that it will continue to run until you actually, manually (by pressing the push button), shut it off? It doesn't matter that you bring the key fob with you when you leave the vehicle...even if the fob is not near the vehicle, since you forgot to shut it off manually, it will just continue to run?
· Premium Member
2017 Summit
There is a real key in the fob. It is not for starting the car. I suggest you browse the manual for how to start the car if the fob battery dies, and to find out what the key is for.
2014 Grand Cherokee
You were clear I was just glancing over the post too quickly. The only thing mentioned in the manual is if the engine is off and left in the ACC or ON position, the car will turn off after 30 minutes of inactivity. Don't see anything with engine running and the key within or out of range.
· Premium Member
It will continue to run. The Jeep is not absolutely and completely idiot proof. It assumes if you've been able to procure a drivers license, and are able to afford a vehicle as technologically advanced as this, you will also be able to remember to shut the vehicle down before leaving it. Although I've seen people stop their vehicles and get out, not only forgetting to shut them off, but forgetting to take them out of gear, and watch a driverless car motor down the street until it crashed into something. Maybe there needs to be a fail safe in vehicles so they shut down if no one is in the drivers seat. That would be just about completely idiot proof, but a real pain in the butt for everyone else. :rolleyes:
Reactions: Willx and bill_de
Cherokee
Thats hilarious LOL. I know you can turn the Jeep off with the fob. you just hit the remote start button and it shuts it off.
Just want to add a little what I know about the intelligent key. I work for Nissan and we have the same set up. If you walk away from your jeep or don't have the key it should alert you on the dash by a visual warning and also an audible warning as well. As far as dead key you pop off the push button and use your physical key like the older jeeps. Ex I know the commander is one with the twist style. As far as dead jeep period I know with my 13. You pull the cup holder insert out take the manual key out of your fob and insert it into the shift lock to get out of park.
· Premium Member
The '14 doesn't work like that. The button doesn't pop off. Instead, it uses a RFID chip in the fob. Read all about it in that wonderful book, the owner's manual.
2014 Grand Cherokee
On the 2014 GC, the start button isn't removed to the start the vehicle with the physical key if the fob dies. Just put the nose of the fob against the start button and start normally. The physical key is just for entry into the vehicle and locking the glove compartment.
If the battery dies and you need to put the car in neutral to push or tow it, how does that work on the 2014, with the new shifter and push start
2014 MY has a manual cable to rear inside the console storage area that is used to place the transfer case in neutral so the veh can be safely towed. If remember correctly a small cover is removed to access the cable handle.;)
Reactions: jacko15
2012 GC 4x4
OP, it's a safety issue. While my example would never happen, it highlights a problem. Say you're driving 70 down the freeway and someone throws the key out the window, it's too dangerous for the car to turn off since the key is now no longer present.
1 - 20 of 38 Posts
