1 - 20 of 238 Posts
Moderator
UPDATE: Added Vanity Bulb replacement
As some members have asked, this is what I have assembled thus far in trying to convert the regular bulbs to LED. I haven't personally been able to do the swaps yet, however they have all been obtained from various forum posts from members who have done swaps here and there. Listed below is a quick chart to figure out which bulb you'll need for a particular application. This is all that I have ordered thus far from XenonDepot. All bulbs I believe are sold in Pairs. Don't forget to use JG exclusive JGLED coupon code for 15% off total too!
Description- LED VANITY LIGHT REPLACEMENT
Color- White
Part Number- 230003
Application- Visor Vanity
Price- $26.99
Description- 194 High Power Automotive LED Bulb
Color- White
Part Number- 280003W
Application - (Rear License Plate) (Interior Tailgate Cargo)
Price- $31.99 x 2 =$63.98
Description- 3157 Nova LED Replacement Bulb
Color- White
Part Number- 234157W
Application - (Daytime Running Lamp)
Price- $62.95
**There is also a new Putco Neutron 3157 billed as the brightest LED ever which should work the same**
Description- 194 LED 360° Replacement Bulb - Amber
Part Number- 230194A360
Application- (Front Side Markers)
Price- $22.99
Description- 7440 Nova LED Replacement Bulb
Color- White
Part Number- 232440W
Application- (Main Reverse)
Price- $62.95
Description- 7440 Neutron LED Replacement Bulb
Color- White
Part Number- 287401W
Application- (Main Reverse) Brightest Alternative
Price- $49.99 on sale at the time of this edit
Description- 921 LED 360° Replacement Bulb
Color- White
Part Number- 230921W-360
Application - (Liftgate Reverse)
Price- $22.99
Color- Red
Part Number- 230194R-360
Application- (Liftgate Taillight)
Price- $22.99
Color- White
Part Number- 230194W-360
Application- (Interior Driver/Passenger Footwells) (Glove Box) (Rear Grab Handles)
Price- $22.99
**For people who want the brightest footwell, this replaces the OEM #906 bulb**
Color- White
Price- $22.99
**Warning- This bulb is not plug and play, resistors are required to avoid the "fast blink" bulb out indicator**
How to: http://www.jeepgarage.org/showthread...ht=LED+install
Description - 3157 Nova LED Replacement Bulb
Color- Red
Part Number- 234157R-
Application- (Main turn/stop/tail)
Price- $62.95
As I find out more, I'll add to this list. Since we have come to find out the manual for interior bulbs is incorrect, Its not as easy as using the original part number from the manual. For example the interior cargo part number in the manual is 214-2 which is a fuse style bulb. I took the bulb out, and it is NOT a fuse style bulb, but like the interior footwell bulb, a 194. Not sure why there are discrepancies in the manual.
Many many thanks.
Thanks for this. So I'm guessing these LED "bulbs" are plug and play? Just remove the normal bulb and plug the LED bulb in?
They are quite expensive though...:slapfight:
Moderator
Discussion Starter #6 (Edited)
Correct!
and yes they can get expensive, the most expensive being the DRL and the Main Reverse (the two most pleasing IMO as they change an offwhite/amber light to pure white). With the coupon though its a little better, and his prices without the coupon are on par with Amazon. If you order a lot he might even be able to do a little better then the advertised 15% coupon.
The only non plug and play is the Main Taillight (not listed), due to the issue of blinker/tail the vehicle registers a no bulb I believe. Im going to add the part number now for those that want to install the necessary resistor I believe to get it to work.
Correct!
The only non plug and play is the Main Taillight, due to the issue of blinker/tail the vehicle registers a no bulb I believe. Im going to add the part number now for those that want to install the necessary resistor I believe to get it to work.
Right on. Thanks for the info:thumbsup:
Tks keep us post.......
Moderator
Discussion Starter #10
This trailer hook up makes installing the led brake/ turn signal leds.there was a post earlier about this install http://cgi.ebay.com/ebaymotors/07-10-Jeep-Grand-Cherokee-T-Connector-Wiring-Harness-/380311563454?pt=Motors_Car_Truck_Parts_Accessories&hash=item588c55ecbe
Yes, this thread shows the install..http://www.jeepgarage.org/showthread.php?t=17590&highlight=LED+install
Most people want plug and play, hopefully something will come about where an LED will work, but maybe it never will be able to without resistors Im not too sure.
Moderator
Discussion Starter #11
UPDATE: Added Glove box, options for footwells, Main Tail/stop/turn, Rear Grab Handles
Cherokee Trailhawk
Thanks for the work assembling all this info!
Reactions: nubby105
Long Live the Grey Ghosts
on xd site they have the PUTCO ones for the visor mirrors........i think you missed those....
here is a pic
Moderator
Discussion Starter #14 (Edited)
Haven't taken out the Visor bulb, so Im not sure which LED part number matches up for chrysler part # V26377. I did a quick search for the V26377 but didn't come up with anything. Will have to ask Steve @ XenonDepot soon.
Waggie
Interior LED questions/advice:
Looks like the stock interior cabin bulbs have a blue tint to the lens. Are you guys doing "white" LED replacements, (other than intentional interior color themes such as the footwells)?
J13ntv, I see where you list 360 degree bulbs, but can/should one use the one-sided LED's in locations that warrant it such as the interior tailgate cargo, rear grab handles, glove box, and maybe exterior license plate?
Thanks for any comments or suggestions.
Oh, and J13ntv, could you stop getting into my wallet, eh?
Moderator
Discussion Starter #17
For the interior I've only ordered the cargo and footwells. Don't think I will replace any of the others, I might not even swap out the footwells if they are too bright, I like the lighting in the Jeep already, but brighter cargo won't hurt, and yes in white.
The license plate and interior cargo listed above are actually T style and not 360. They have the light at the end of the stick and facing down. The interior bulbs I guess are all preference, the bulbs in the car are obviously all 360 as stock, however if people want to experiment with one sided sticks, be my guest! I'd imagine a T stick would also probably work well in the footwells as the light is supposed to shine downward.
N/A :)
Reactions: TTUMBIO2010
moose my pic SHOWS NO BLUE IMO........its pure white. now I do have blue footwells but that pic above of my 2 center overhaed and 2 sun visors is WHITE AS RICE BABY! imo of course.
Moderator
Discussion Starter #19
I think moose was talking about the stock bulbs giving a blue tint not LEDs. Although some cheap LEDs do give a bluish tint.
1 - 20 of 238 Posts
