My Jeep Grand Cherokee 2012 5.7L has the auto setting on the AWD setting. I heard that with full time AWD, the tires has to be keep at the same wear otherwise transfer case will be burnt. . But I have been thinking how can I possible keep them the same wear. there is always a small difference even if we diligently rotate the tire every year. As a result the front axle will always slightly rotate at different speed than the rear axle, thus the transfer case clutch is rubbing ? can someone please explain the internal working of transfer case and the weakness it has with slight difference in tire wear. . How can the design of the jeep transfer case be so rigid such that the difference in tire wear can not be tolerated ? Nobody can maintain precise wear on all 4 tires. Nobody..
I have had my transfer case burnt already because of this difference in tire wear even though I rotate every year. I do not want to happen the second time. I wish Jeep has the 2WD rear only setting like the GM trucks such as Chevy Tahoe. It really does not make sense that all four tires are actively pulling the vehicle in hot summer time, where there is no snow. What for ?
