Yeah well i'm sure your scan tool will show the same thing.
I haven't spent a ton of time watching those parameters but from what I recall, it will not match what your shows.
I do not have a 2014 to test, but when I find time, I'll hook up my 2016 and see what it shows .
I'm sure this is wrong too right?
The T-Case backing off clutch lock pressure in relation to steering angle so the drivetrain doesn't bind up either?
No, thats exactly how it's supposed to work .
People always want to refute my testing but never can and just go based on opinions and no identical testing data to prove otherwise
I believe you are getting bad data . I have zero confidence in any scantool that is not OEM. They have a history of not reporting or interpreting data incorrectly .
There are times when the factory scan tool will not display the correct data, simply because its not been programed correctly.
You are only seeing what engineering wants you to see, and unless it's been proven to be accurate, then it's not reliable information.
I've gone down many a rabbit hole only to told I was chasing bad information , so the first thing I question now,is the information.
Im not your enemy here, you have spent a lot of time ,its obvious, I just do not trust the source of the data.
I wish I were closer to you, we could get together and run those same tests with a MicroPod and see if anything comes up different.
