Ok after owning and driving my Jeep for a few weeks now I have a couple questions.
1. My HVAC system when I turn the engine off I can hear what sounds like the doors moving. I have not really investigated but like I said it sounds like the doors are moving inside the enclosure. Is this normal or do I need to investigate further?
Also I ran the diagnostics on the HVAC system. At least I hope I did it correctly. I pressed both the ac and recirc buttons together then turned the left knob one click. I got an error code that if I remember right was for my blend doors. But I get both cold and heated air out of both sides. But while I turn the left knob I can get a bunch of numbers and they are sequential. 1,2,3,4... so on and so forth. I really really need to get a manual.
2. When I first start out and I turn the wheel sharply I get a rumble in the front end. but after I am driving for a while I get no rumble. It only happens when I am going slow and the vehicle is cold. Like I said after I have driven for a short period of time it does not do it. Any Ideas? I have yet to get the front end off the ground to check suspension components for wear. Also I see no evidence of tire rub. The tires are the stock size and the suspension is stock.
I am sure there will be many more questions.
Now for some background on me. So you can see you are not talking to a total bone head hehe. I have over 30 years experience as an automotive mechanic. I have worked on about every type of wheeled vehicle built. But my experience with Jeep products is VERY limited. I can count on my one hand the number of Jeeps other than military M151 Jeeps I have worked on.
I really really need a few days where I can jack my Jeep up and go over it with a fine tooth comb and also get me a good manual.
