1 - 20 of 28 Posts
Laredo
I am now in the process of doing the rear end SRT to my jeep and i am looking up the parts needed in the justforjeeps section and am wondering if i need the bumper absorber or do i already have that on my jeep. im geussing its the foam piece? ive got the bumper, all i would need is the clips and the 2 lights aswell the chrome strip. My other question is about the chrome strip, does it come with the park sense holes?
for reference to what im speaking about
SRT8 Rear Bumper Package
Thanks,
J
You will need the bumper absorber which is made of plastic...not foam. This will replace your existing absorber. Order the chrome strip without the sensor holes since you do not already have the sensors in your original bumper. Part number is 5159087AA.
Laredo
can i use the old foam absorber? and as for the chrome strip i want to install the sensors! so im geussing i should get that done as well!!!?
i believe scottie tried cutting/modding the old absorber but no luck. looks very similiar tho.
rear bumper,SRT absorber,rivets wit rivet tool, chrome strip, rear fogs
I remember Scott saying that you would have to remove so much material from the absorber to make it work that there wouldn't be much left of it. Do you already have the Parking Assist control on your control center in order to add the sensors. How do you activate them?
Laredo
i dont have a control unit for the rear bumper assist, do i need that? isnt the parking assist when its in reverse it goes of with a beep when you get too close?!
Laredo
i geuss il order the rear absorber! do you have a rear srt?
yep check my avatar. for the exhaust, i recommend do not use the SRT muffler for the V6s
Laredo
Discussion Starter · #10 ·
wasnt planing on anyways! too expensive to buy, i have my own custom build exhaust done! :)
Laredo
Discussion Starter · #11 ·
Laredo
Discussion Starter · #12 ·
does this chrome strip come with the rear assist holes?
Chrome Strip
Laredo
Discussion Starter · #14 ·
ok ok cool, and for the park sensors if my wk doesnt have the park assist? can i still do this? and can i do it myself?!
There's a PDF of the installation instructions on the link I sent you earlier. Looks easy enough. Doesn't look like you have to have the disable button on the center console for it to work. Also, confirm with the dealer that it doesn't need to be activated with the Starscan Tool. With parts you're at about $500 (if you do the install) Ouch! Good luck with the mod. Now's the time to do it along with the SRT rear bumper.
What is this custom exhaust mod you speak of???
Laredo
Discussion Starter · #16 ·
yea i figured id do it, if i were installing the rear bumper, but il have to think of it twice!!!
and the custom exhaust has been all made from scratch 3" tubing! bent to fit through the old exhaust then out the middle, i just have to delete the spare tire for my fitings to work (Thrush Welded exhaust). basically a new line from the muffler out! (where it was all rusty befre) and the tips are split at the rear just for the look! all this for abour 200$
500$ for the parksense intall? dont all i need is the parkesne and thats it?! wiring etc? plus the 4 little sensors?
I was adding shipping to the Mopar Kit ($300) and the chrome rear strip ($150) with holes which you need anyway since you're converting your bumper.
Sounds like a fun project.
Laredo
Discussion Starter · #18 ·
yea the rear is that last thing thats to be done! im excite to finish my jeep! especially my custom exhaust! and the rest! will be activating the rear fogs and customizing the srt bumper!
Laredo
Discussion Starter · #19 ·
ok so i finally have my rear bumper painted and ready to install, i have a few questions! im sure you could be of some help! my first question is, with the new absorber is just plug and play, will it fit right in?! my second question is the 2 fog lights that need to be put in, are they clip ins or they need screw? and if so does it come with it when i buy them! thirdly i see i need 3 bumper clips? where do those go? and forth can i use my existing rear step pad or do i need a diffrent model?!
Thanks for the help y'all!!! :)
Laredo
Discussion Starter · #20 ·
1 - 20 of 28 Posts
