1 - 2 of 2 Posts
Manual shows 3057 but it looks like a lot of search show the 3157 as equivalent. The manual shows the 3157 has the drl.
So, what model is best? 3057, 3057 LL , 3157 LL etc...
Anyone have any luck with the led versions?
Tia
Pfeifler
2012 GC Laredo X
They are basically the same bulb. You can use either one, but I would suggest just putting in the 3057. If you go with LED, you will need resistors, and you'll need to measure the housing depth. I tried installing LED's in our front turn signal but the socket wasn't deep enough for the LED bulb.
1 - 2 of 2 Posts
