power is not power...
you will definently hear the difference between dirty power and clean power...
Can you elaborate on this. Im curious what "dirty" power is.
I personally have JL amps. I bought the 450/4 because of the high power output and it is very flexible with what its capable of running. I like the R.I.P.S feature on them which puts out full power at 1.5-4 ohms @ 11-14.5 volts. There was someone on another site that was talking about JL amps, saying he tested a 500/1 and it was putting out full power even when the cars voltage was below 9 or 10 volts. The JL's have a bunch of diff crossover filters built in, the 500/1 has 6 which im not even sure what they do, though most if not all amps have some type of filter/filters. "Crossovers are groups of individual electronic filters which allow only certain frequency ranges to pass through them by attenuating frequencies outside the selected range. These filters allow the user to specify what frequency range will be sent out of each channel section of the amplifier. This, in turn, allows each speaker system to only reproduce a range of frequencies it is well suited for, resulting in reduced distortion and improved fidelity." (taken from the jl install book)
I think matts statement is absolutely true, power is power. Though not all amps are created equal in how they are capable of performing in terms of power output and frequency filtering. Not sure about other amps, but the JL amps show how to adjust each channel to its maximum unclipped output level easily with an AC voltmeter, which I remember on my other amps i'd be listening by ear turning the gain up waiting to hear distortion which doesnt seem that accurate to me.
Im not really in the loop with all the diff brands anymore, but when I was looking around for all my gear that I have now I heard Focals in a Tweeter before they closed, and they sounded very good, loud and clear. I really like how the Focal K2's look and the Utopia's are just insanely expensive around $4,500.
