1 - 2 of 2 Posts
08 overland
Hey everyone, new but no new here!..I am in serious need of how to, install a better quality backup camera on my 08 overland. THe factory one is milky and blurry looking..I found the wiring diagram, for the factory camera, but I need to figure out since ours is a plug into harness type, what I need to mod on the aftermarket one to wire it to plug and play directly into the factory one..THanks!
2008 WK Stormcaller
Four pins used.
http://www.wkjeeps.com/nav/park_view_03.jpg
Backup lamp feed is power, ground goes to the JACKET DRAIN, signal goes to tip, return goes to ring (ground). Basically if you crack the tailgate and look at the connector, it'll IMMEDIATELY be obvious. No modifications forward of the liftgate connector are required.
Output / input is actually analog (RCA) with additional pins to turn on/off.
1 - 2 of 2 Posts
