1 - 20 of 62 Posts
How difficult do you guys think it would be to replace the copper trim on the black interior with silver one?
From what I have seen I would need to replace the door open handle surrounds, ac vents, center console trim, steering wheel trim and instrument panel surround.
Just trying to get a feel of how difficult it might be if I decide to do it once I have my truck for a few months.
I'd like to know how difficult it is to remove the trim pieces. I've thought about hydro-dipping them with something like a brushed aluminum. The silver dash trim on my Ram will soon be dipped with a diamond plate pattern.
Man, when I sat in a 2014 Overland with black interior that silver trim with a slight bronze hue looked soooooooo good. You sure you want to switch that out for the bright silver plasticy looking stuff? When sitting in the Jeep it looks so good and its not overdone even the slightest.
I used to work in a auto electronics installation bay and im willing to bet with how many pieces you would be swapping and some of them being smaller brittle plastics, the chances are pretty high that you will end up breaking some sort of tab or a piece wont fit back in correctly. So keep that in mind when you start removing parts of your brand new Overland.
Here are some nice shots I took of the interior and center bezel of a black interior Overland. I know its all personal opinion, but this looks 1,000 times better than the bright silver ones that just look cheap. Obviously its your car and you can do as you like, but IMO you would be degrading the look of your brand new Overland and more than likely breaking atleast one tab while doing the swap. I have a feeling your gonna end up loving it anyway so it doesnt matter :thumbsup:
High Altitude 4x4
You would have to replace the steering wheel and that's not a replacement with matching wood. The only replacement that might work is the SRT steering wheel. But then the brown wood might look out of place. The copper hue is very slight and at certain angles the trim pieces look silver. Plus, the brown and black in the wood works with the copper hued trim pieces and black leather in my opinion.
I say on an overland with black interior as well and it does not look bad. I guess it's more of me being used to silver trim on all my previous vehicles. I do plan on giving it some time after I take delivery before I make any final decisions. The little time you get on a test drive on it is not enough to really get a day to day feel on it. I guess it has more to do with a personal preference for me. And you are right, not too sure I want to be picking at the small pieces on my 50k car just for being a little picky.
I was not sure how the steering wheel was built but I was thinking I was going to have to replace it. Which probably is not worth the money when I have a working one. Just gotta learn to like change and be different from most vehicles out there. I just need to give I a real shot after I take delivery.
I was worried about the copper color initially, but it has grown on me and fits in well. Depending on the lighting, it will look silver and I think the copper works well with the polished silver trim around the cupholder and center stack.
AFAIK, the real "copper" trim is exclusive to the Summit with the brown interior, although I certainly could be wrong about that. But the regular "silver" trim has a slightly golden hue to it, even in my MY12 JGC.
Discussion Starter · #10 ·
From all the pictures I have seen it is copper trim. It has been more noticeable when being hit by direct sunlight. But I dont see any gold hue to it. Comparing it to the trim from the black interior on the overland to the brown interior on the summit, the trim is identical in color. (Brown interior left - Black interior right)
Discussion Starter · #12 ·
What about on a 14 limited with the Lux II? I was assuming this wasn't an option and I would be receiving bronze. I just placed my order last week...can I get this changed to the silver?
Only the black interior with the Summit gets the silver trim on the inside. All others get the bronze trim inside with the black. No way to change that.
Thanks for clarifying. I was against the copper/bronze look at first but it def. is growing on me a lot.
Discussion Starter · #14 ·
Yeah same here. I guess I am just not used to seeing it.
In the Summit interior photos on jeep.com, the Jeep Brown interior clearly has the copper trim and the black interior clearly has "silver". There was a video link posted awhile back...probably in the features thread...that had a Jeep representative actively discussing the copper trim innovation for that new interior.
Discussion Starter · #16 ·
If you scroll through all the pictures you can see that the one you are referring to is the summit black interior, which does have the sliver trim as i pointed out. However, on that page, under the dashboard shots section. Dot 1 is the summit black interior with silver trim. Dots 5, 7 and 8 are the black interior for overland, limited and laredo respectively and you can see the copper trim clearly on them.
I was referring specifically to the second picture which is Jeep Brown--that's copper. That other trim you mention on the Overland, Limited an Laredo is identical to my MY12...it's silver, but the paint has a slight bronze hue when the light hits it a certain way.
Jeep Grand Cherokee WK2 - 2011 Grand Cherokee interior describes a "slight gold hue" for the Laredo and Limited and only uses the word copper with the Summit, although the photos at Jeep.com show silver with the black. Silver is referenced in the Overland description.
Please believe me, I'm only trying to help clarify what has been told to us by both the insiders here at JG as well as from other references. The "copper" really is unique to the Summit.
Discussion Starter · #18 ·
Jeep Grand Cherokee WK2 - 2011 Grand Cherokee interior describes a "slight gold hue" for the Laredo and Limited and only uses the word copper with the Summit. Silver is referenced in the Overland description, although the photos at Jeep.com show silver with the black.
Fair enough. I did not know you were comparing it to your MY12 as we were talking about MY14 and the trim color it has on each model with the black interior. I was just going on what I have seen from test drives and pictures of the MY14.
Yes, that "slight gold tone" changes as much as many of the paint colors do in different kinds of light!
Discussion Starter · #20 ·
I did notice that. Ultimately i would have wanted the sliver one but its a compromise I am willing to make, for now at least. :D
1 - 20 of 62 Posts
