Thanks for the residuals. Do you have the money factors for both banks?This is for Limited
36 mo - 57%
39 mo - 55%
At 10k miles, subtract 2% for 12k miles and 3% for 15k miles.
Money factor will depend on the bank. US Bank is much better than Ally.
Not good for me! Thanks though.The residuals I've seen so far (here and other threads/people) are ridiculously low on the Overland but the Limited model looks really good when it comes to residual.
I just don't understand the logic behind it...
More expensive models typically have worse residuals, as they depreciate more.The residuals I've seen so far (here and other threads/people) are ridiculously low on the Overland but the Limited model looks really good when it comes to residual.
He nailed it on all points.The Overland will be worth more, but not the same percentage more. Lets say you buy a $5,000 option package on a $30,000 car. Essentially 17% of the cost of the car.
3 years down the line, is that car worth 17% more than a car with the same option package? No. Might be worth $1,500 more. The package depreciated at a much higher rate than the base car.
If you look at used car values and play around with KBB, etc you see that.
Thats why when leasing the smart Jeep to lease is probably an absolutely loaded Limited vs a base Overland. Cost and equipment may be very close, but because the Limited is a Limited the residual is going to be better and the lease will be cheaper. Whereas if you are buying the Overland will probably actually be worth more on resale because "its an Overland".
