1 - 1 of 1 Posts
I have a question that hopefully will be easy for someone to answer.
I have bought a Nav TV Allgig for my MY12 Overland export model.
I'm using this to enable a camera on my caravan to be displayed on the factory screen.
Now to enable this to work I need to install a switch that will allow me to switch between the Jeeps factory camera and the one on the van (when connected).
I'm assuming that all I need to do is install the switch in the power wire for the Jeeps camera and the power wire for the van camera goes on the other side of the switch, correct?
I took this off WK2Jeeps. Is the power wire for the Jeep camera the one I've circled in red?
And if so, are the colour codes correct so I know which wire to cut at the plug behind the headunit?
Cheers,
Matty
1 - 1 of 1 Posts
