I went to my local 4 Wheel Parts and picked up some Rigid Duallys and clear covers to replace my rock chipped and melted stock fog lamps. My goal was to have some bright and clean fog/trail lighting. These lights run just like the stock do as far as coming on with the low beams and turing off with the hi beam. I also added a switch so I can run the Fogs with the hi beams on for trail lighting.
When I got home I made up some brackets quick.
Bolted them in using stock holes.. There is one tab on the front that needs to be sanded down. Just used a sanding bit.
Testing... To wire I just cut up the harness they gave me and spliced it in the jeep wiring after cutting off the stock connector.
All the lights Running
From in the cab with all the lights on
