I saw a post with a guy with the exact same symptoms, turned out he needed his transfer case replaced.....Hi guys. Had the same issue, service 4wd light comes on after 5 min drive. Clicking sound from underneath, ( can hear with open window). Took to the jeep service center. Transfer control module has been raplaced. Problem solved.
Grand Cherokee WK2 , 2014
72k
Running into this very issue with my 2014 overland. Took it to the dealer and they are saying the transfer case needs to be replaced. Quoting me almost $6,000. Pretty much laughed the guy off the phone. They also want to replace the thermostat at $400. Looking around for a second opinion but might give this transfer control module a shot. Will already be replacing the thermostat as that's an easy swap.Hey everyone, just closing the loop here. So I took it to the dealer as stated above, they quoted me $2,600.00 for a new Transfer Case, Transfer Case Motor, and Transfer Case Control Module. When I asked what had happened, they told me that the TC was binding up causing the motor/module to fail. This didn't sound right, but lets play along.
When I asked them if they would contact FCM about the Powertrain Warranty because that seemed a bit excessive as it was only 2 months beyond the 5 year mark and well below the 100k mark, they told me that there was no way FCM would cover it and even tried to state that the warranty wouldn't have covered it which was a lie.
When I told them it was still too expensive and I would need a second opinion, they came back with a proposal and this is where it got really fishy. They told me if I was willing to replace 2 Engine Mounts and do a differential fluid flush on both front and rear they would waive the cost to replace the other parts. Cost: $1,600. When something seems too good to be true, it usually is. How could a dealer offer me $2,600 in parts/service if I was willing to pay the regular price of $1,600 for engine mounts/fluid flush? They would have been better off telling me they'd cut the $2,600 down to $1,600 and call it a day.
Instead, now knowing my WK2 was fully out of warranty, I decided a second opinion and some research was necessary. The truck was still driveable although I would be careful with it. The dealer told me it was a one-time offer and that I'd be back and they couldn't guarantee the same offer would be available.
I hit up the forums here as well as spoke to a coworker who just happens to also have a WK2 (still under warranty). He has a shop at his house, so I guess I've found my new place to work on the Jeep if needed.
Pricing out the parts vs what the dealer quoted me, I decided to take a phased approach. I would start by replacing the Transfer Case Motor with a brand new one first, and then go down the line. Even if I ended up replacing the TC itself, I figured I would still save money.
I replaced the TC Motor, which unfortunately did not fix the light. I was still getting a clicking sound every time I shifted in or out of gear as well as turned the wheel at a stop. It would occasionally bind up when slowly turning near full lock (turning in/out of parking spaces) and then would break free. The light would be off initially upon start up and for the first few minutes of driving, but would turn on again at highway speeds.
I'll admit I wasn't the quickest to order the next part (TC Module), but I did begin sourcing one. While doing this, the behavior of the Service 4WD light changed. Instead of ticking and binding up, the light was on upon start up and remained on all the time with no ticking or binding up.
New TC Modules require flashing by guess who? The dealer of course. Researching this I discovered that it's not VIN specific flash, I would just need to source a used one that matches the year/options. Off to Ebay. Found one for $200 that came from a parts vehicle, 2014 Overland. I decided to give it a try.
Replaced the TC Module (under the drivers seat) by removing the fuse first and then plug and play with the module, and all is back to normal. No Service 4WD light and it drives perfectly normal.
Total Cost - $609.00
Total Time - 45 Minutes
Difficulty - 3.5 - Overall it was pretty simple, but anyone not comfortable crawling under a vehicle might be a little uneasy. If you've ever replaced anything under the vehicle, this couldn't have been more simple and straight forward. The Module was plug and play, like adding a new fan to your computer tower.
One thing I did notice was that both parts seemed to be newer versions. I can grab part numbers if anyone would like them.
Me too here ,same problem,part number please..Running into this very issue with my 2014 overland. Took it to the dealer and they are saying the transfer case needs to be replaced. Quoting me almost $6,000. Pretty much laughed the guy off the phone. They also want to replace the thermostat at $400. Looking around for a second opinion but might give this transfer control module a shot. Will already be replacing the thermostat as that's an easy swap.
Could you share the part number you used for the transfer control module?
Many electronic modules are shipped "disabled" and must be enabled by the Dealer tools, and they set it up they must be enabled after they are installed...New TC Modules require flashing by guess who? The dealer of course. Researching this I discovered that it's not VIN specific flash, I would just need to source a used one that matches the year/options. Off to Ebay. Found one for $200 that came from a parts vehicle, 2014 Overland. I decided to give it a try.
Faulty Tire sensors would just cause the TPMS warning light to light and codes for TPMS problems....Can faulty tire sensors be the cause of ,...
I boght rims with sensors 2017 & up,without knowing about the sensors,(tire pressure sensors)mine is a 2014 Summit,also i changed fluids in front & rear diffs,& t case ...![]()
Well i went & got it diagnosed(Jeep Dealership) rear diff motor,ordered & waiting to come,update will be as soon as i instal it..Faulty Tire sensors would just cause the TPMS warning light to light and codes for TPMS problems....
Unless you mess up the fluid change, i.e. to low a level or used the wrong fluid, that resulted in mechanical problems that shouldn't cause the 4WD Service warning....
You need to read the stored fault codes that are causing the warning to light, to even get a clue as to what might be wrong....
Cant translate..[QUOTE = "سبانخ ، مشاركة: 2021129857 ، عضو: 101429"]
2014 أوفرلاند مع 62 ألف ميل. انبثق ضوء نظام الدفع الرباعي للخدمة مباشرة قبل مغادرتي للبلدة وغادرت بسرعة. عندما عدت جاءت على اندفاعة وهي الآن تعمل بالكامل. تسير بشكل جيد مع عدم وجود أعراض أستطيع أن أقولها.
أخطط لإجراء بحث أكثر تعمقًا في المنتديات ، ولكني كنت آمل أن يتمكن شخص ما من الحديث بسرعة عما يمكن أن يكون عليه أو يوجهني في اتجاه قبل أن أحدد موعدًا للنظر فيه.
هو موضع تقدير أي مساعدة.
[/اقتبس]
I know this was an old post but did you get it resolved? I have the same car with similar miles.with this issue, do you think I could try just replacing the TC module before replacing the Transfer Case Motor?? I am having an issue with my 2014 jeep cherokee trailhawk...the svc 4wd light is on, but no noise as of yet. Also, it looks like my engine moves when I start my vehicle...should that be?? Could that be part of my problem as well??? My vehicle has about 120k on it and my warranty is over.
I would like the part # please...Hey everyone, just closing the loop here. So I took it to the dealer as stated above, they quoted me $2,600.00 for a new Transfer Case, Transfer Case Motor, and Transfer Case Control Module. When I asked what had happened, they told me that the TC was binding up causing the motor/module to fail. This didn't sound right, but lets play along.
Hi, My light came on tonight on my way home… car wouldn’t accelerate over 48. I pulled over, turned off and restarted. No problem on the rest of my 40 min drive home. Wondering…. How much was the transfer control module?Hi guys. Had the same issue, service 4wd light comes on after 5 min drive. Clicking sound from underneath, ( can hear with open window). Took to the jeep service center. Transfer control module has been raplaced. Problem solved.
72k
Thanks for sharing! These are the exact same issues that started this week with my 2015 Jeep Grand Cherokee Overland (104K) just days before I was going to trade it in. It's been at the Jeep dealer for diagnosis for 2 days (but they're not sure when they're going to have time to get to it). Depending upon what they say, I'm wondering if I can just drive it to another dealer to buy a non-Jeep car (This is my 6th trip to repair issues in the past month). Help!Hey everyone, just closing the loop here. So I took it to the dealer as stated above, they quoted me $2,600.00 for a new Transfer Case, Transfer Case Motor, and Transfer Case Control Module. When I asked what had happened, they told me that the TC was binding up causing the motor/module to fail. This didn't sound right, but lets play along.
Rear diff motor..I have the same issue of service four wheel drive light but i have changed the transfer case module (under driver chair 05150732AE ) and slip differential motor (68214628aa ) and no solution , any help?
Yes i already changed also as i mentioned above ( slip differential motor (68214628aa ) ) but stillRear diff motor..
Acutator
Have you checked the rear diff module,it i located under the drivers side rear seat...or broken wires from module to rear diff motor ,as soon as the weather gets better ,im checking the rear diff module,....I changed rear slip differentia module , rear slip differential motor and transfer case module , but the same issue (service four wheel drive system), the repair shop advice to change the whole rear differential. any advice?
